$1000, has some issues, some of them I solved, for example, cts(both plug and sensor), starter fuse, climate control unit (a/c button froze and was always on)elbow that attaches to intake is ripped (ordered one already)
some other Issues need to be tacked, caliper right rear for example,is frozen, windshield cracked,throw out bearing is getting noisy, and the hot and no start issue, this one has me boggled, tho although i did my homework and found about the bad fpr or leaky injectors, althought if i stomp on the throtte it will start, (chime in on this issue would be appreciated), speed sensor, like most s13's is shot (im not spending 250+ on the oem nissan one) napa will do,cracked radiator, and the one that has me worried, corrosion
Never been drifted on, this one spent all its life as a daily driver until the owner bought herself a 2012 camaro, then it spent the remainder of its life sitting, body is dent free, (front fenders are bent tho) and it needs paint
So what's your opinion,fellow niconauts, awesome find!!!, its ok or get rid of it asap! Be honest, ill appreciate the comment, whether good or bad
