eliterit »
https://forums.nicoclub.com/eliterit-u12096.html
Wed Oct 11, 2006 10:09 pm
tonight i decieded to install a boost controller on my stock turbo ca18det.
i was messing around with the controller as it is a manual type with the highest setting set to 14psi on the stock sidemount. of course this was its peak and it would settle down to 12psi.
i knew that was a bit too much even though it is a bit cool at night in texas right now, so i turned it down to peak at about 12 and settle at 10psi.
the car seemed a decent amount quicker, or should i say not so slow, and later that night i went to wash the car.
after the carwash i left and gave it a nice wot in first and near redline i hear something similar to a intercooler pipe popping off. I pull over and check all the piping and could not find anything to be wrong. So i take off and the car will not make any boost whatsoever and i can hear a metal to metal noise as the rpms rise very slowly.
i know i shoudn't have taken the stock turbo past 10 psi on the stock sidemount and i'm not here to get a lecture on it. i got the entire car dirt cheap with the swap and i really didnt care if the turbo blew or not. more reason to upgrade egh?
what i would like to know is if any of you guys have used those ebay ssautochrome gt28 turbo kits for the ca18. I've seen kits recently as low as 750shipped to my door that include fmic with all piping including hot pipe, tubular manifold, turbo, manual boost controller, greddy knock off bov.
with all that i find it hard not to purchase the kit seeing as it comes with all that stuff. the only things that im wearie on the kit are the turbo and greddy knock off bov.
so hopefully someone here can give me some past experience with these kits and the ca and i can make my decision.
thanks
