So how exactly do you replace/add fog lights?
diego1212
Car: Nissan Versa
I just recently picked up some led fog lights on ebay for the Versa and I have no clue how to put them on...I know you have to cut something, but I'm dumfounded- anyone, help?
versabundus
Car: 2007 Nissan Versa
If you have no clue, I suggest you wait until a factory kit is available. Affixing a universal kit is quite involved. I did it but I had to make custom stainless brackets and cut the holes with a 3 1/8" hole saw. It took a lot of fitting to get them right. The wiring isn't that easy either if you have an "S"
MIdnkight-lude
diego1212 wrote:I just recently picked up some led fog lights on ebay for the Versa and I have no clue how to put them on...I know you have to cut something, but I'm dumfounded- anyone, help?
with the factory system. the actually fog covers pop out and you jsut add in the fog lights. now i didnt see any pre-wired setup on the S model. so i dont know if hte SL model has it pre-wired for fog.
Elmojo
Car: 2007 Versa SL
Yes, the SL is totally prewired for Fogs. Even the relays and fuses are installed.All you need to have is the actual lamps assemblies and the switchgear.I'm hoping Nissan will release these soon.
BenzTech Gone Versa
Car: 2007 Nissan Versa 1.8SL
Well The Dealer In Valley Stream/Long IsLand Has The Fog LightsAnd Its About $300. for the Pair. Still Need Another Cover And Switch Though!
diego1212
Car: Nissan Versa
dang...o got some jdm lights for around 80 bucks...is it just me or do you think that stock parts, etc. are way overpric ed at dealerships?
BenzTech Gone Versa
yeah its way too much for the lights.i got a pair for 30 bux and its got h3 bulbs with the xenon look.my friend is gonna try to install them for me this morning.we are gonna cut out the plastic opening on the covers and wire the fog lights off the parking lights with a relay.also the switch it came with is going next to the mirror switch.i guess thats were the sunroof switch would go if i had one..lol.
diego1212
Car: Nissan Versa
where did you get them?i want some cheap ones now...i can jus return these
BenzTech Gone Versa
diego1212 wrote:where did you get them?i want some cheap ones now...i can jus return these
R&S Strauss. I Pulled off the covers and matched up the size of the cut out to fog lamp diameter.yeah so i did the install.....had to engineer(hack) the covers with epoxy to get the foglamp to mount and aim properly.looks awsome though!
Mudd
Car: 2007 Versa Hatchback SL
Pictures would be nice!
BenzTech Gone Versa
http://community.webshots.com/...Versa
Modified by BenzTech Gone Versa at 4:40 PM 1/7/2007
Chrispd100
Car: 1977 280Z, 1987 Stanza, 1994 Sentra, 2007 Versa
so yea i went to walmart and bought a pair of fog lights for 20 bucks and i have to say danm... 20 bucks well spent...
Quotacious
Car: Rentals on weekends
Chrispd100 wrote:so yea i went to walmart and bought a pair of fog lights for 20 bucks and i have to say danm... 20 bucks well spent...
What was the manufacturer/brand or model for those? And were you able to directly connect them to the existing cables in your car (SL)? Etcetera.
Chrispd100
i can't remember what brand they were. I got them off the self at walmart for $21.** and i had to cut out the plastic unfortunately cause mine did not pop out. and there were no wiring harnesses on my car so i just grounded each light and then ran a cable into the cabin and connected it to the dimmer that controls the interior lights so that one i turn on the parking lights the fogs come on automatically. It all in all took me about 2 hours to do just because i took my time cutting the plastic with a soldering iron cause i did not have a dremel and i did not want it to look like crap.
Jun_alejandria
Car: 2000 NISSAN MAXIMA SE, 2007 VERSA S AT, 2007 VERSA S 6SPD
Hello, Great Job on the fog lights!!!!!!!!!! Wish I could hire you to install mine. $300 is too much for OEM fog lights for me. Your's is an H3 XENON halogen 55w lights? What diameter is the lamp, 4"? Do you still remeber what brand? Do you have the lamp screwed into the mount, and lastly is the fog light behind the plastic cover or is protruding? Hey, sorry for all the Q's, but I've been waiting for OEM fog lights just to find out it cost $300. I'll spend $60 at the most and a shop will install it for $50. I'll work on the plastic cover myself. I wast wondering if you any pics of the fog light installed without the plastic cover....thanks for listening and GREAT JOB!!!!!!!!!!!!
KimberKenobi
Car: the Camel
dude, can we get a close up of the light with it off so we can see the fit?
beautiful color BTW!!
VersaMitch
Car: Nissan Versa SL
Does anyone know if you can just put a switch inline with the input and output from the BCM for fog lights? If so, then I'm not waiting for nissan to make a kit, I'll just put my own lights on and splice in my own switch. It should work the same as the light switch arm.
