turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Mon Jun 09, 2008 3:13 pm
my car is destined to never hit more then 4psi!!!
i thought i had a boost leak form my intake manifold gasket, took off the whole intake manifold, changed all the gaskets, eliminated all emission crap form the obd2 manifold, cracked my thermostat housing in the process only to still hit 4psi still!!
wtf? i cant figure it out, i just want to get rid of the car now. i have a new tial wastegate on a 7psi spring and a mbc that is cranked up, i should be hitting 10 psi and im only getting 4!!
i went too two shop fixed all the leaks they said to and still only 4psi, where is it leaking form, i see it hit 5-6 psi initially and tapers off the 4..
wastegate source is directly from the turbo im so stumped... i have no vac lines dangling around, fmic pipes are good and tight. no holes, i dont know anymore.
this problem has happened since january its now june, i know the car has potiental to be fast but it just donest want to. im so frustrated if i dont resolve this by august im selling the damm car and getting a 350z. and calling it a day.. im sick of working on this damm car and not getting no returns,,,
