So, finally ran at the track with my '08 G37 automagic
audtatious
Was better than I expected with the automatic transmission:
60': 2.100330: 5.8671/8: 8.967 @ 79.141000: 11.6301/4: 13.861 @ 100.76
Jacko3
Well done! Those results are great and they seem about right for 330 HP ride. I keep saying it as well, if i have to buy a G-37, i would buy the automatic transmission----seems more responsive than its manual transmission version. However, I don't know if it is as reliable as its manual transmission siblings----with and/or without a power adder.
Modified by Jacko3 at 6:24 PM 11/8/2008
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
Thats really GOOD!
audtatious
Automatic did great. Shifts were at redline and firm.
Jacko3
After test driving the manual transmission G-37, i felt the transmission was way much higher in capacity than the engine---mismatch in my opinion. The engine appeared way too underpowered for the very beefed up G-37 manual transmission. The G-37 manual transmission could handle an engine with over 400 horsepower without any issues. I would dare say that it is more beefed up than the G-35 manual transmission. And then the shifting is even shorter than that of the G-35---almost no need for a short shifter in a G-37 manual transmission.
If I had my way, i would twin turbo a G-35 Coupe engine and then install the transmission of a G-37 manual transmission. This set up will awaken a true beast.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
nice work! post a slip on drag times!
What track did you run at? What did you beat?
audtatious
5 runs. Beat a late-90's vette due to reaction time only and a modified mustang because he broke up during his run. Lost to a '72 Cutlass, a SC Mustang and cnichols LS1 240sx.
Once the day wore on I lost traction as the last two runs (14.4 and 14.0) resulted in lots of wheel spin due to all the "pro-style" cars laying a ton of rubber down. Now that I know the sweet spot for launch (brake torque to 2000-2200rpm) I feel I may have been able to get a 18.7 during an early run.
There was a stock 335i at the track as well and we talked a bit. He was having problems with traction control fully releasing during launch and was running 13.7-ish with a high speed of just over 103.
audtatious
Actually, looking at my slips, the above was not my best time...Best time was actually a 13.835
60': 2.128330: 5.8901/8: 8.972 @ 80.021000: 11.6201/4: 13.835 @ 101.89
How'd I miss that???? FWIW, the fastest run was the first run of the day and my first time running the G at a strip. Knowing what I do now I should easily be able to pull off a 13.7 time if I go before there is a lot of rubber laid down.
Here's the slip. I'm car 35 and car 6 was the Vette so I guess me beating him was not simply RT:
G_whizz
Car: 2010 G37 Coupe Sport
Geez...those are REALLy decent times!
Nice job Matt... vids next time tho You should already know this.
zozoka1212
Car: 08 Infiniti G35x
Nice kill.
The vette was doing better till 1/8 then he lost to you.
Interesting.
zozo
audtatious
G_whizz wrote:Geez...those are REALLy decent times!
I know there is a vid of me lining up against Chris but that is the one I over brake-torqued off the line and got the 14.4 so I don't know if it's worth anything.
Jacko3
I completely agree with you on the vette. I once went at it with a vette and all he did was spin his wheel like crazy and his reaction time wasn't as great either. I think i have a post on that encounter somewhere. Some factors that can affect performance timed runs.
1. response time
2. Wheel spin and tire grip
3. wheel size
4. heat soak, humdity, etc.
audtatious
He hooked pretty well....
Response time has nothing to do with your ET as the clock does not start until you leave the line. Reaction time can simply give someone a win when they in fact had a slower run. In the case of the vette, he had a better 60' and 1/8th yet I had a better overall time (did better in the last 1/8th) and would have beat him even if my RT was not better than his.
soul_hfk
Car: 2010 G37xS---08 QX56
nice run
Jacko3
audtatious wrote:He hooked pretty well....
Why would the clock start differently for two cars dragging? If thats the case, then each car can drag on their own without a need to show off with other cars, isn't it? Response matters a great deal, however you might feel about it. Each drag strip from what i understand, have their own rules.
zozoka1212
There is 2 point on the drag strip. Get a good car right beside yours and try to beat it and try to beat the time.
One car can be faster and end up in the finish line as second.
zozo
audtatious
Response does not matter to ET times. I didn't say RT didn't mean something in regards to winning a race. A few of my races I didn't pay much attention to the tree but was focusing on other things. Now, if I was actually not doing test and tune then I would have been all over the light.
gwoods
Nice work! your DA was 686 feet above sea level.
I wonder how you would do with Nitto 555R drag radials?? Christmas IS next month isn't it?
audtatious
I won't run it again until I get some mods done or next spring sometime. DR's would def cut the time down but by how much I have no idea.
Jacko3
Ok. I see the point. Thanks.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Not bad at all for an "old timer"driving..
audtatious
Cool, you got my first run on the side with the working timer
For some reason I thought that was a 18.9 run which is why I didn't mind taking the left lane the rest of the day as I thought I was faster on it.
Oh well
gwoods
[QUOTE=RED_DET]QUOTE]
That is a great picture!!!
I need to take a road trip to LA just to run a sea level. My best time was at my best Phoenix DA of 2286 feet
suby01
Car: 2007 Infiniti G35x
that means that your car is faster than mine i need quick.
