So finally decided to replace struts
Qxx4
Car: Infiniti qx4
So my 03 qx4 has over 300000kms and the shocks and struts are shot :crazy: and i found a KYB dealer here in dubai and they gave a very good price for both struts but my question is what should i consider changing while changing my struts?
01pathfinder7
Car: 2001 pathfinder SE
Likely new top mounts. You'll want to change the rear too all four at once. Inspect your control arms, bushings, sway bars, cv while your there or prior to install.
AlanAZ
Car: 2003 Infiniti QX4 RWD
Be careful with which top mounts you use. Lot's of reports here of after-market top mounts failing early. OEMs last, and a few others are known to be good.
Qxx4
Car: Infiniti qx4
by top mounts you mean this:http://apxautoparts.com/sensen-front-st ... ranty.html
and can you provide the part number please
and what do you guys recommend for rear shocks?
i asked for KYB just a gas shock but its out of stock so i need something else
botched_lobotomy
Car: 2001 Infiniti QX4 | PSB RCA Poly Bushings | Michelin [update needed] tires
Are KYBs good? All I keep seeing is that they promise to restore to factory ride. I'd like something a little stiffer. Or am I just wishing for something that doesn't exist?
