so confused. MC help please?
Mastaflash
Car: cars
i searched and read through all the related posts and still came out lost. im doing the z32 26mm upgrade. heres my questions.
do i need a specific year for the calipers, or all na calipers the same?
which master cylinder should i get? i learned not to get tokio, but to get nabco(?). what places sell the brand i need? anywhere other than Nissan? which size is best? is bigger always better?
what modifications must be done to get the MC to work on a s13 w/o ABS?
please dont just go off and say search. i did. and these arent the hardest quastions in the world, i just dont know which is best.
navysnail
all years are the same i belive, for na. get the nabco, it says nabco on the side and you could probobly get it at a junkyard.the mc, if i understand right, will fit with no modification on an s13 w/o abs.hope this helps
Mastaflash
Car: cars
ok. its just hard to find good solid info. theres probobly as much wrong stuff as there is right out there.
navysnail
there was a post on that like 2 days ago, some one copied a web site on there that had how to hook everything up with pics and exactly what could and could not be used for the swap.
navysnail
found it, its the second one downhttp://www.nissaninfiniticlub....58395
Mastaflash
Car: cars
thanks alot.
S13 King
Car: cars, performance, girls
here don't know if you've seen this but here ya go.
http://www.princeton.edu/~asad/zbrakes/
curious to know why not go with 30mm?
