SO CLOSE!!!
br0k3n_240
hey guys... i just got a ca18det and swapped it into my s13 and i am so close to getting it to run but its not getting any fuel, so far iv figured out that the pump is workin and i dont think my injectors are getting any signal to fire... any ideas? i followed the instructions to wiring up an sr20det. also i know its fuel bc the engine starts and runs for like 5 seconds on starter fluid and i know its not the pump because i can turn the car on without the fuel line attached and it pours gas out. also when the car is running on starter fluid my tach doesnt give me a reading could this be related? i know injector signals get their signals in the form of engine speed. thanks for any help in advanced.
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
if i remember right the cam position sensor is what gives the injectors the signal to open. that sounds possibly like your problem
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Are you sure that you have you CAS installed in the correct position ???
br0k3n_240
yeah it came installed... i talked to my boss at work(i work at a shop) and he said i could possible just run a new b+ cable to the injectors bc im pretty sure theyre getting signal from the ecu which grounds it but i dont have any b+
edit: thanks for the help guys, i just ran new wires from my ecu and from a switched ignition to the injectors and voila, it started right up lol
Modified by br0k3n_240 at 10:52 PM 5/24/2008
