ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Sat May 09, 2009 4:41 am
very nice, but you WILL have much more stress on your hubs and suspension components, the weight of your car will be moved farther our, which to a certain point isnt bad, at that point( with 1 inch of wheel under the car) the weight will be inside the wheel centerline, causing MUCH more stress on your hubs
there is a reason cars are designed with the wheels width bulk, under the car, you dont see any racecars with crazy offset wheels, just extended width stance and light weight, im not bashing the idea, go for it, it would look crazy when properly fitted, i just think its more for a show car
