Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Thu Aug 12, 2010 9:33 pm
If you think you're going to have your Pathy for a while, I'd suggest finding some used alloy rims. Check local classified sites like Craigslist and kijiji. Alloy rims almost alway look better than steel ones, and they won't rust with all the salt and moisture that comes with winter driving. Either way, though, definitely buy a second set of rims for your winter tires. In Alberta, it's about $100 to mount different tires on rims -- that's $200 a year -- unless you buy your tires from a shop that offers free mounting/unmounting for the life of the tires. Also, tire shops are hopelessly backlogged in late fall and springtime because everyone wants their winter tires swapped on/off. If you buy winter tires now and have them mounted on separate rims now, you can skip the lineups and swap them on and off at your own convenience.
I was somewhat lucky when I was looking on kijiji and found a set of stock QX4 wheels for $600, with enough rubber for at least two more summers. I eventually mounted the winter tires I bought on my stock Pathfinder rims. (Compare $600 for alloy rims and 2 years of rubber, to $320 for new steel rims alone.)
The typical suggestion is that you get narrower tires than the stock size for winter driving. The theory goes that, with narrow tires, you'll cut through the snow and slush easier (same weight, less surface area = more pressure to push the snow away), making it easier for your tires to make contact with the asphalt instead of riding on top of the snow. That said, I still went with stock size, and bought a set of 255/65/R16 Nokian Hakkapeliittas. I'm sure others will chime in with their tire selections, but let me say this: with few exceptions, in snow and slush, the worst winter tire will outperform 95% of all-season tires out there. I've been fairly happy with my Hakkas the last two winters, and they're barely showing any wear.
Studding your tires offers more control and shorter stopping distances on slick ice. On the other hand, your handling on dry roads will suffer, they can be very noisy (especially at highway speeds), and in some states/provinces they're illegal. I'm not too familiar with Aspen (or, for that matter, anywhere in CO), but in Edmonton there's a decent crew for winter road care (plowing/sanding/salting/etc), so studding tires is a bit overkill here. I chose not to stud, because (a) like I said, it'd be overkill here, (b)I like to travel to BC, where studs are illegal, and (b) I do a ton of highway driving.
Finally, make sure to compare prices online and locally. Online prices can be way cheaper (I paid $520USD for my Nokians, which went for $1400CAD locally), but if you buy locally the shop often throws in benefits (such as free mountings). I'm not too familiar with the online shops, but if Google doesn't help you, I'm sure there'll be others on here who can.
