expertie wrote:My J30 has 215/60/15 tires. A few years ago, I bought Bridgestone Blizzak WS-50 tires and this year I noticed a bubble on one of the tires. I am not sure how bad it is to drive a car with that tire. Will 225/60/15 snow tires fit on the factory wheels? Even if it they fit, is it a good idea to use different size tires?
225/60 is a bit bigger so your odometer will be running slower. The size must be good as long as you run the same size on the same axle. Also for the winter tire you want your tires be narrower and with higher walls. If I'm not mistaken the recommended size for the winters is 205/65/15
