lain wrote:My questions;
1)In your situation, I'd use chains in the mountains.lain wrote:What will I need in order to drive on snow gracefully...and possibly ice as well. I kinda looking for something that is cheap but dependable, if I have to sacrifice cheap for dependable thats alright.
2)No.lain wrote:Where is is snow is there always ice?
3)Yes. Once you've totally lost control, that's probably ice.lain wrote:Is there a way to tell the difference between snow and ice (on the road).
4)Practice before hand.lain wrote:What will happen while driving on snow or ice, will I suddenly slip into one dirrection? What can I do to prevent this or if its too late what can I do to regain control of my car?
5)Avoid the mountains.lain wrote: What should I expect? What should I advoid?
David
Dependable + cheap = chains. You will have to be outside the car to put them on/take them off. They give more traction than snow tires. They also have the added drawback of a very low maximum speed... Chains are not meant to be driven on more than 35-40 MPH, and will snap if you drive them too fast or if you drive them too long on bare pavement.lain wrote:1) What will I need in order to drive on snow gracefully...and possibly ice as well. I kinda looking for something that is cheap but dependable, if I have to sacrifice cheap for dependable thats alright.
Good adviceCopyChief wrote:First thing. If you're too nervous, get someone else to drive their own car
What exactly does this mean? I've always heard it termed "turn into the slide." Which basically means keep your front wheels in line with the road, no matter which way your back end goes. To me "steer against the slide" would mean the opposite. We may mean the same thing....just semantics.CopyChief wrote:Steer against the slide.
Oh great. First time driver on snow/ice and you'll be stoned. Excellent combination - hazardous conditions and dulled reaction time. Perhaps - just perhaps - you should A) avoid doing this completely, or B) you could put down the bong for just a day to do this unimpaired.lain wrote:So I guess a stoner won't have any trouble driving in the snow.
I guess what I was really interested in was about driving on the mountains cause by the time I get to the city I don't really care...there is no 1000ft drops. I'll be sliding around all day there. I rather hit a tree then fall off a clift.
And starting on 2nd when on ice.LinWin wrote:Lots of good advice.........one more thing, down shifting in snow and ice can keep you out of trouble. I live in Canada, lots of snow here. Using the gears to manouvre is key. Good luck.
Ummm...No. Not quite. If you're understeering in a FWD car, it probably means you're going too fast for that corner, or trying to turn too sharply (again think subtle, deliberate actions) Giving it more gas will just increase the problem. Let off the gas, don't touch the brake, and try not to turn too sharply.motoguy128 wrote:The improtant thing ot remember when you start sliding with a FWD car.... you need to give it some gas. Lifting throttle or applying the brakes will mke the situation worse. This applies if the car is "understeering" (Plowing, pushing the front end, not turning), or "oversteering" (loose, stepping out, sliding).
I'll second this. You'll maintain better control of the car if you let the engine break while going down hill as opposed to pressing and release the break. Just remember to shift more slowly than you normally would. Meaning, release the clutch more slowly so that there is more time for the engine speed to adjust to the wheel speed and/or rev the engine with the gas while downshifting.LinWin wrote:Lots of good advice.........one more thing, down shifting in snow and ice can keep you out of trouble. I live in Canada, lots of snow here. Using the gears to manouvre is key. Good luck.
Not in all conditions. Engine braking can cause problems where it causes the wheels to break lose. Like if you are going down a really slippery hill. Your wheels needs to turn at road speed to effectively steer. If you engine brake in those conditions you might not stop and also can't steer which can mean a crash. So if it slips under engine braking hit the clutch let it roll again and use the ABS there's no ABS like function on your engine. On VW cars they actually have something call Engine Braking Assist that helps prevent slipping due to engine compression.Great White Versa wrote:
Lol I'm just messing around...I'm not going to smoke while driving there (my gf would have a fit and thats something I would't want to deal with). Also my reaction time doesn't change one bit...I use to work as a professional gamer...you have to have a fast reaction time to to get in that kinda field of work. I'm not talking fast like, "wow that was fast", I'm talking fast like, "wtf how did he just do that!" kinda fast.Rockhound wrote:
Like you said, you'd hate to fall off a "clift" [sic].
I know exactly what understeering and oversteering are...i use to drive a 240sx.motoguy128 wrote:...Any way to visualize what the car is doing. Have you played a videogame where you were a space ship with a single rear thruster? You had to turn the ship to change direction or slow down. A sliding car is very similar to this. I'm not saying you need to spin into a 180 or put hte car in reverse to stop the car. But just applying the brakes or steering into a trun doesn;t always work in a FWD car.
awww... was this because of me? If so, then I'm a killjoy... sorry!WDRacing wrote:*EDITED* for present company
question: do snow tires reduce the snow build-up on your wheels and wheel wells?lain wrote:Ok I live in a part of Cali where I never seen snow once. But I have gone to the mountians a couple of hundred times but never drove there myself.
My questions;
2) Where is is snow is there always ice?
3) Is there a way to tell the difference between snow and ice (on the road).
4) What will happen while driving on snow or ice, will I suddenly slip into one dirrection? What can I do to prevent this or if its too late what can I do to regain control of my car?
5) What should I expect? What should I advoid?
Anything extra you think I would need to know before driving on the snow would be great or I'll just end up finding out the hard way, either way I'll end up learning, this is just a little easier.
Thanks
