Snorkels for cold air?
Fosty
Car: 2001 Infiniti QX4 2WD
Would a snorkel provide colder air because it's away from the hot road?
macgiver
Obviously , the closer it's placed to be scooping up relatively colder air - your NOW getting 'colder air' . :crazy:
Fosty
So is it better to get a snorkel rather than a cold air intake, for performance, not just keeping it out of water?
PapaSmurf2k3
Site Admin
Its a little more complicated than that. A snorkel is usually a bit more restrictive than a normal cold air intake.
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Agreed ^ Your planned application is also important. For example, If you're looking for improved street performance, I suggest a traditional cold air intake. But if you're planning serious off roading, that includes stream crossings/flooded trails or dusty trails, a snorkel makes more sense due to it's higher mounted opening. Not because of being away from a hot road, but a combination of lessening dust/debris that extends the life of your air filter, and slightly reducing the risk of water damage plowing thru water.
