I was just wondering if anyone else has this issue and has found the solution.
At slow speeds (less than 5 km/hr) my rogue makes a rotational clunking popping noise. The noise gets faster with vehicle speed and goes away completely after 5 km/hr. The noise seems to be worse when going up an incline slowly (like my driveway). The noise sounds like it is from the front, I previously tried replacing the RF cv shaft for this issue and it did not repair it.
I know there is a service bulletin to replace the electronic coupling on the rear differential - has anyone done this and does this repair this issue? I’m thinking that maybe what I am hearing is the transfer case when the electronic coupler is not working properly?
