That sucks. Find someone with an extra stock one and him hook you up. The ARP ones aren't CA specific and I can't remember off-hand which part # is used as the main studs in my built engine. I can tell you one was kinda long and I had to do some physical adjustments with a hammer and punch tool .JNM240 wrote:Ok, so im torquing down the main journal bolts with my (old) torque wrench set to 40 ft lbs. Tightening them down in sequence per the FSM, a little at a time. The torque wrench never clicks, so i keep tightening. Then *SNAP*, the main bolt in the center (intake side) snapped!!! CRAP! I might have to remove everything (got the pistons all in, and the rear main seal plate in) and take the block to have it machined out.
Damn it all, too. Yesterday i was helping one of the techs at work remove a transmission from a 6 liter turbo diesel Dodge Ram duelie and it slipped and clocked me in the face. An emergency room visit and 5 stitches under my left eye later and i got to stay home today. Great cause my FMIC came. AWESOME. But now this!! What a setback!
Anyone know if ARP makes the main bolts for the CA? And probably, while im at it, what about the connecting rod nuts?
I was really hoping to get the bottom end put back together and put my freshly painted and polished oil pan back on.
Actually if you have 2 pair, you can put the first pair on the bolt and use the second pair to tighten the first pair up enough to hold it so tight it will either turn the bolt, or break the vice grips.r34 gtr wrote:yeah, vise grips can un-stick almost any bolt. you just gotta adjust them so you and a friend can just barely close them.
I bet its because the CA18DE didnt come with a crank girdle....and the DET did...what are the measurements and thread pitches of the main's?JNM240 wrote:Ok, crap-o-la.
8 of the 10 came in with the last 2 being cross shipped from a different warehouse. Took the 8 home. Dont fit. Way too short. By like an inch. They are the same thread pitch and look the same, but are just shorter by about an inch. And they looked them up via a 88 Nissan Pulsar NX SE with a CA18DE. So now i gotta return em and take a lot of measurements to have ARP whip me up a set of studs. And it'll probably be in the $200 price range. O well, more piece of mind i guess.
