Snag in the ET to DET conversion
McAdam
Car: I like cars and my motorcycle. boats are fun too
well, I ripped apart the pulsar CA16DE and found cracked-into-tiny-peices rings in all 4 cylinders, no biggy. But no girdle, I have heard that CA18DET's have girdles on the bottom ends? Also, cracked into the 1985 CA18ET and found a 6 bolt flywheel instead of an 8 bolt that I was expecting. should be fine tho as I am using the 200sx bottom end and the pulsar top end, right? questions or comments anyone???
As a side note, the con rods on the pulsar motor look like all the pictures I have seen of CA18DET stock rods.. havent busted out the micro meter yet... I havent gotten that far into the turbo motor to see what the bottom end looks like, I'll let ya know when I do, if anyone cares
cheers, McAdam
hopeful
whats a girdle?
So your using a ca18et bottom end (assumably w/ pistons and con rods) with a ca18de head?
I'd really like to know how this goes, I'd like to do it myself if its possible.
(aren't you on club-s12.org?, don't you wonder why they advise for this swap to NOT be done?)
McAdam
a girdle is a ladder looking thing that bolts to the main bearing caps and holds tehm all together as one unit so they dont move around under high HP. And yes, I am on S12.org I am using a CA18ET bottom end that is getting rebuilt and a CA16DE head that I had 500 miles on when the rings in all 4 cyl decided to self destruct. My guess as to why they dont advise this swap is the wiring would be a pain in the ***. From what I have gathered tho, the mechanicals of it all it looks like a bolt on process. Pistons in the CA18ET block have 4 valve releifs in them already and the stock DE pistons were domed to go into the combustion chamber. so, wiht the ET flat tops, I should be fine with compression. Dont worry, I have a digital camera and I plan on documenting the hell out of everything! TheMadSceintist said the head gaskets are a spot on match, so I dont see why it wouldnt work. Someone over on freshalloy.com did this and got away with 312 crank HP on the stock NA CA18DE computer out of a pulsar! but that was like 2 yrs ago, I have had no luck contacting him lately. anyway, pics going up tomorrow!! sorry to ramble,
Cheers,McAdam
themadscientist
The CA16 also has a 78mm bore vice the 83mm of the CA18. The cranks are the same dimensions but I am not sure if they have similar strength. The girdle is a DET thing, I would think all you would need is the girdle, main caps and bolts from the DET to convert a CA16 or CA18ET but you may need the DET pan, it could be deeper to clear the girdle. I am not sure if that is required but it is something you would want to look at. As I mentioned the dimensions on the cranks are the same(exept for the CA20, it has a longer stroke) so if you wanted eight bolts all you would need is the DET crank.
McAdam
heres the links to some previous discussions on this topic Freshalloy.com thing another one, started by me thats all I got for now..... can't remember where I got the 312 hp number, I think it was an email I deleted, oh well, have fun!
McAdam
hopeful
[email protected]
Thats his email, I found it in the threads you just showed to me.
U say you have pics? I'd love to see, [email protected] please!
