305aznG35 wrote:Hey guys, I ran in the same trouble with this axact 10 pin connector breaking loose. I've done searches all day and this thread is pretty much all I found. I've tried what you guys talked about with no luck.
If you guys've fixed this, please help me out too. Thanks
see if this helps.
http://www.crutchfield.combottom of the screen there's a link to
More Info:Technical SupportOrange box "Search our online support center"Search by keyword: 2004 G35
the search results will come up and you can pick from with Bose wiring diagram or without Bose wiring diagram
this will show you the ten pin and six pin connectors, the color wires and where they go in the connector harness, but be aware that the pin out #s on the crutchfield site do not match up with the pin out #s from the service manual.
