You mean just cut like a square of metal out and weld another square that is the same in? And if I weld it in wouldnt the welds be sticking outwards? How would I get rid of it so its a smooth finish? And isnt it hard to weld sheetmetal?leesredgt wrote:First: How the heck did the metal get bent outwards and not inwards?
Second:You could just beat it down with a flat hammer untill you get it close then bondo it,but that would be a heck of alot of bondo
Third: Just cut the section out and weld a new one in and bondo over the welds.
why would it pop off within a day? I think it'd stay longer if i bondo'd it as is because the unevenness and the texture of it would make the bondo more likely to adhere to it, whereas a smooth surface would provide no grip.Hcraig13 wrote:Cave and Pave baby.
Not really but since i am bored i will tell you step by step what needs to be done. First the metal is pulled out to far becuase of whoever previously worked on it. Those holes are from the old style of metalwork before the new style stud guns. First Weld the holes. Grind the welds down smooth with grinding wheel. Next use a stud gun to weld copper studs on to the panel in all the sunken places. Pull dents out with a slide hammer until they are realtivly flat. The metal is obviously streachedso when you pull the dents you will need to heat the metal, compress it, and quickly shrink it with cold water. Once all metal is fairly smooth blok it with 80 grit including a little farther than the damage. Bondo time. Put a couple medium layers of bondo to get a good shape. You may then want to use icing(Thin bondo) to get the final shape. Blocking the bondo with 80 and then 180. Then primer the whole area over the 180 scratches. Block the primer with 320 then DA everything with 800 and its ready for paint. If that is an actual crease as if it kind of looks to be it will be almost imposible to pull that. If you have not done this several times i dont not suggest it as that is very serious body work. Just whatever you do Do Not bondo over that whole thing. It will pop off within a day. I seriously suggest taking it to a body shop but its gonna be exspensive. Hope i could help And good luck with the whole car. Any more pictures i like the color.
Edit*** Please dont listen to the other people on here and please dont do it yourself. There is no way to weld that quarter from the inside. Strut tower anyone????
ca18detgabby wrote:clearly that horse has 3 broken legs.........
livinglegend2100 wrote:maybe i missed the thread about it, but... how the HELL does that happen? just curious
what do you mean by panel bond?livinglegend2100 wrote:if i were you i would go to a local junkyard and have them cut off the rear qp from another 240. then just cut out what needs to be cut out from yours and panel bond the new one on. there are some skilled body guys here than can further tell you how to do that. or just go to a local shop and ask them about it. it sucks, but there isnt a snowballs chance in hell that bondo can save that.
woot. 1000 post...
