i got an 89 240 with the SOHC , 5 speed. 168,000 on the whole car and motor together. starts up and runs perfect...when i get on it in neutral it smokes quite bad...like up at around 4000-5000 rpm it smokes like a MOFO! , bluish whitish smoke , also when yu rev it with just the throttle body cable control there it some minor smoke comming from around the engine..its a darker thicker smoke tho...i just changed the oil and added some Restore with CSL and Bardahls No Smoke and Stop Leak oil conditioners...lemme know what you guys think and what should be done...hopin its nothin major..also how much is the typical rebuild(sohc)(for just new pistons and rings) and what is the typical price of a newish(70000-120000miles) DOHC engine?without the swap , just the motor...but thanks alot and any adivce is appreciated
Garrett , NY
SOHC -STOCK
