Smoking problem...again
Temjin
Car: Fixin up me car. And studying
I have a problem but I think it would be best if someone took a look at it other than me. Im kinda new to some of this stuff. Here is whats going on. Beware its kinda long.So a couple of months ago my engine started to smoke. I determined that it was the turbo because the smoke was coming from the turbo area. I didn't have enough money to replace the turbo at the time. Now I do, but something else is now bothering me. Now that the temperatures around here are about 90 degrees the temp gauge is going crazy. I also discovered that after a little while my anitfreeze was almost gone. So I refilled it. No more over heating. But there is still lots of smoke. It smells like oil but it almost looks like its not coming from just the turbo area. It doesn't smoke all the time. Its only when Im stopped at a light for a long time. I just think that if someone took a look at it, they would instantly know what was going on. Any body in the columbus area care to take a look at it for me?
boost_boy
Sounds like your valve seals to me or you could have excess oil in your exhaust from your previous turbo dramas. If it is valve seals, you'll need to pull the head for a head job. Or it could just be another crappy turbo, especially if it's another T deuce and a quarter.
Dee
Temjin
I have yet to replace the turbo. Before I replaced it I just wante to know if that is the problem. If its not then I won't replace it right now and I will use the money to fix whats wrong. It just seems like more smoke than before.
biosehnsucht
what color is the smoke?
if you're losing coolant maybe through some freak accident its slowly leaking past the seals (if any?) around the turbo for the coolant and thats whats burning?
boost_boy
Here's a lesson to learn , so pay close attention. CA18s are old (as discussed before) so we must expect the unexpected if and when they occur. Those T25 turbochargers can only take so much and age is evidently working against them. Basically what has happened with your car is not so much the valve seals, but your turbocharger's seal has cracked and it's allowing both oil and coolant to make it out of the turbo and into the exhaust stream. It's common for this to happen and happened to every T25 I've ever owned.
Dee
GotBoost4Yall
Car: Cars-DSMs/Nissans
Just replace the turbo and work from there, all I know is that next time I'm replacing a turbo ,the motor is coming out.
slw240sx
Car: 1990 Ca18det 240sx Hatch
or the coolant lines on the turbo are just loose and leaking water out on to the turbo , its smoking mostly under the hood also , am i not correct? see i never did get that small problemn figure out, its not new i didnt have time to get back behind that manifold before you drove it home, thats one of the main reasons i wanted to wait till the next weekend.
float_6969
I was just going to say what Jon said. It's possible the coolant connections to the turbo are leaking and it's burning there. Some investigation with a flashlight should help...
boost_boy
Quote »I was just going to say what Jon said. It's possible the coolant connections to the turbo are leaking and it's burning there. Some investigation with a flashlight should help...[/quote] it is very wise to block-off coolant lines if you can. The tiny T25 likes to crap itself a lot and shatters it's cartridge causing the effects I mentioned earlier. Always go after the turbo 1st as It is the oldest and most frail of all the compnents.
Dee
float_6969
To expand on what Dee said, the ONLY reason that the coolant lines are there are for AFTER the motor has been turned off. Due to convection it draws the heat away from the turbo. As long as you have a proper cool down time, there is really no need for them.
float_6969
Hey, if you still want my turbo Temjin, please let me know, as I'd like to get rid of it ASAP. Thanks!
Temjin
lol yeah I still want it. I was just asking around to make sure I was doing the right thing first. I was actually waiting on you to email me back, telling me you were ready.
float_6969
No prob. I'm just impatient. "...I got no patience, and I hate waitin..."
Temjin
lol Im going to buy it. Im going to purchase it on Monday morning. I sent you an email
GotBoost4Yall
The T25 that came with my motor took a shyt on the first test drive, I was actually concerned because the smoke out the exhaust was white, opened the hood and saw white puffs around the manifold and it smelled like a burnt clutch. Taking that shyt off was a *****, you need lots of patience and good tools. Got an SRT25 for now, its boost happy.
iliketocrash
on the note of valve stem seals... they're not that difficult but they're tedious as hell to do. i helped a friend do a valve steam seal replacement on his DSM a few nights ago. It was my first one. I love working on cars. :ylsuper
NeedCAforS13
Car: CA swapped S13 coupe
I did them in my CA head... took awhile, but yeah, they're easy once you do one:)
Sean
