This needs to be in the tech section
I'd check the orings first. What color is the smoke? Blue is oil, white is coolant or fuel. So if it white and wasn't smoking before, then I would check your orings. Also, did you have your ecu chipped? If not, then the ecu is throwing 50% more fuel into the system than it thinks it is
