numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Sat Nov 12, 2016 6:04 pm
As a wedding gift for a friend, my buddy and I told him we would fix up his honda and sell it for him. It's a 1996 accord with the 2.2l sohc vtec. This thing smokes like a chimney. White smoke with a strong fuel smell. It had an egr code.
We changed oil, new plugs and wires, new cap and rotor, new pcv, replaced egr with a supposed working used unit. Compression numbers are
1 - 180
2 - 155
3 - 180
4 - 180
Leak down test of cylinder 2 produced audible air noise inside the engine. We pulled the valve cover, blocked tell oil return passages and did the test again, noise was dampened.
Also, while doing the compression test we both heard a loud pop under the valve cover between cylinder 1 and 2. Did the test, compression on #2 was on par with the rest, started it up and no smoke. Retested, popped again, compression back down, and smoking again.
We're confused, anyone have an idea?
