SR20Essex »
https://forums.nicoclub.com/sr20essex-u41694.html
Sat Sep 09, 2006 8:21 am
Let me start by saying I hate wiring; especially the interior type.
2 months ago my break light fuse blew so I upped the amp of the fuse from 15 to 20 a couple weeks later that blew so I went to 30. All the time I was checking the wiring and grounds for the exterior lighting (didn't find any problems).
2 weeks ago while driving I started to smell something burning, pulled over and my fuse box was smoking/melting (nearly caught on fire), I managed to pull the smoking 30amp fuse out with a pen (first thing I found).
For the past two weeks, I have rewired the break lights; I even got the upper break light to work which has not worked since I got the car. When I say "rewired", I mean pulled the old ones out of the break switch behind the break pedal and ran them through body paneling back to the lights themselves.
However, since doing that (I have no idea if the problems are related), my clock (in the main gauge cluster) wont keep the time (until the door closes), the radio doesn't work, the main overhead interior light doesn’t work and the automatic seat belts wont retract when I open the door unless the key is in the ignition and turned to at least acc.
Two things that bother me the most:When I close the door, my clock comes on at 1:00, and it keeps time until I open the door, then it goes blank, and the red door open light on the same cluster wont ever fully go out, it just goes dim which causes my alarm to act funny because it thinks the door is still open.
I checked the door switch, all grounds, both of the wires that were bypassed for the lights, and read the every interior wiring diagram in the main service manual; but still cannot find the problem.
Someone please help, I am completely open to any ideas.
the only two wires that I cut to fix the break lights were a red wire with a green stripe, and a red wire with a yellow stripe (the only two wires connected to the break pedal switch).
