Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Sun Jul 18, 2004 8:08 am
Your engine won't get used to it. If you have a higher-mileage engine, then the synthetic does not condition the seals well. It will leak right through the gaskets that hold conventional oil well.
Not really a problem, except that you will leak a bit of oil over time, get your engine bay really dirty, and keep smelling the distinct smell of syn oil burning as it runs down from your valve cover gasket to your ehaust manifold.
I would only put synthetic oil into a car that has between 20k and 50k miles, and I would switch it out after the car hit maybe 120k.
