Well got my passenger side axle seal fixed because I thought it was the cause for my oil burning smell. Well just got home from a 15 minute drive and noticed the smell again so I popped the hood to check it out. Seems most of the smoke/burning smell comes from the piece where you put in fresh oil, under all the wiring. Appears to be coming off the top.
What would cause this? Im thinking may be a bad valve cover gasket?
Other side (drivers) seems have some residue built up, but definitely not smoking from them. Is this something that should be done together?
Lastly...How easy is the passenger side to do myself?
