Smoking Engine (95 Maxima)
AutoShadow
Car: 1993 Nissan 240sx
My friend's 1995 Maxima has been smoking recently, its not a fire smoke, almost a coolant mist. He had his radiator replaced a few days ago, but it seems to be still leaking. It is still smoking after the radiator replacement, but doesn't seem to be overheating?
I hope you can help me. That's pretty much all the info I know....I'm a 240sx guy.
AutoShadow
Anyone? The coolant seems to be leaking still, and almost smells like burning plastic or chemicals.
Bump.
AutoShadow
Bump....
coolhand
Car: 1995 Nissan Maxima SE
Where is the smoke coming from? Radiator? For somewhere in the engine department? If there is spillage of coolant on the radiator that may take a day of driving to burn off. After that something is leaking.
sicivic89
Just like the posted said. Where is the smoke coming from?
AutoShadow
The smoking appears to be coming from the front of the engine near the fan. I'm thinking its a bad belt, since it smells like burning plastic/rubber. Any thoughts? Thanks.
AutoShadow
Bump....the maxima forum doesn't seem to be as lively as the 240sx forum...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Has he checked all the coolant hoses? Made sure they're sealing at joints?
lightsout
Car: 00 Nismo Maxima SE
has he checked the water pump to see if it is leaking slowly onto the belt, and getting burned off?
did he hook up the transmission cooler properly?
does it sound like the belt is slipping?
check the hose connections, coolant may be spraying onto the exhaust manifold or y-pipe.
put the car up on blocks so you can look underneath it w/o any problems...warm up the engine, and then check for any fluid leaks.
We have plenty of Maxima here, it takes time for people to respond, stay persistent!!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Coolant smells sweet kind of like maple syrup.
I would spray the engine compartment with water (cold engine) to get any coolant out of there.
Then warm up the car and see where the "Smoke" is coming from. It's possible that one of the hoses wasn't attached properly and is getting melted.
