Smoking around 3000 rpms
Jok3r synestro
Car: 1990 nissan 240sx
Ok, got a new head gasket installed, along with new valve stem seals, Ive searched but cant find any topics about the problem, it starts and idles fine but when you rev it to 3k rpms or higher it blows blue/white smoke from the tailpipe. compression is good all the way around. any ideas?
slidestyle69
Car: 92 s13
Your car is blowing up, you should call 911 immeditaley and have internal surgery done
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
check your oil if it looks like a chocolate milkshake. blue white smoke suggest that you are burning oil and coolant.
Jok3r synestro
oil looks ok, but im gonna do an oil change in a few days and see if it gets any better, prolly got coolant in the oil when i took the head off to replace the gasket and seals.
nifares240
the mating surface may have warped and not seating the gasket properly.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
if you had a blown headgasket and didn't change your oil after fixing it that is probably your problem...
Jok3r synestro
Pulled the head originally to check the valves and install new seals, head gasket wasn't blown. im wondering about switching over to synthetic, think that would help?
sommmatt
Car: 1989 Nissan 240SX
Jok3r synestro wrote:oil looks ok, but im gonna do an oil change in a few days and see if it gets any better, prolly got coolant in the oil when i took the head off to replace the gasket and seals.
FLUSH OIL IMMEDIATELY.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Jok3r synestro wrote:Pulled the head originally to check the valves and install new seals, head gasket wasn't blown. im wondering about switching over to synthetic, think that would help?
Not at all.... So you never overheated... hmm I wonder if the heads surface is ok. Either bad install on the headgasket (bad positioning, improper torquing, over torque), or the head has warpage and needs milling.
Most machine shops check heads for like 25 bucks and will mill them for about 45.
Jok3r synestro
pulled the intake and exhaust manifold so it would set right on there with no problems, sprayed it with copper sealant, and torqued to FSM specs. it hasn't overheated, id think it would smoke at idle and start up if the head was warped. im not gonna start it again till after the oil change to prevent any further damage
