kouki_monstor »
https://forums.nicoclub.com/kouki-monstor-u33270.html
Fri Jan 06, 2006 4:34 pm
i have an 89 sohc 240sx. i just replaced the injectors cuz ive been driving it with 3 cylinders for the past 2 months. it drove like crap and shaked like crazy and made me wanna throw up. i just got new ones today from a guy at a local shop, four of them still in the rail (only a few months old) for $75. i decided, hell, might as well change all 4. so thats what i did. after i replaced them, i started the car, and BAM!!, white smoke comes out of my exhaust and some in my engine bay. it looks to be coming out of the hose that connects to the PCV valve and other areas i cant locate. it smells like unburnt fuel, and it still shakes like im running on 3 cylinders. i tried pulling the connectors off the injectors while the engine is running to see if it makes a difference, and it died when i pulled it off 3 of them. but when i pulled it off the 3rd injector (the one that needed replacing), it doesnt make a difference at all. im guessing its cuz one of my injectors isnt working still (but why? i just replaced all of them) and that im not burning enough fuel, so its making white smoke all over the place. i thought it was the head gasket, but my coolant in the reservoir wasnt boiling or even hot. it was just warm like how it should be. and plus, if it was my head gasket, wouldnt the engine overheat after like 5 minutes? i drove it up and down the street to see how it would run, same ol same ol (still shakes, still no power), and i felt like i was driving a damn rocket (50 ft of white smoke behind me). i didnt replace the o-rings when i installed them cuz they looked fine, so could that be the problem? could it be causing one of the injectors not function correctly? or could it be that one of them is clogged and not spitting out enough fuel to drive the cylinder, so its not burning enough fuel? or could it also be the spark plugs? not making spark to burn off enough fuel so the fuel is just sitting there? i thought it was cuz the connector on the injector was bad, but i plugged it into the old rail that i removed when my engine was running, and it seemed to spit out fuel just fine. i dont know what the problem could be. could unburnt fuel be causing that much smoke to be coming out of the exhaust AND engine bay? plus, i thought unburnt fuel smoke was black? what do u guys thinkg could be wrong? please help!! thanks alot!!
