Same exact thing happened to me except I have a KA24DE, Ill search for my post and that has everything you need to know in it.
*edit* well I found my post but its a lot of stuff and kind of confusing, so Ill just tell you what happened.
When you replaced your injectors, gas got down into you cylinders and ate the oil seal around your piston rings.
this is a decently easy fix
1. Buy new oil, filter, some sort of hand pump that can reach down into your cylinders through the spark plug holes, and the smallest size of Marvel mystery oil (you can get this at any auto parts store).2. Drain all your oil, most likely will have lots of gas in your oil.3. Pull your plugs and put the pump down in there and pump any gas/oil mix out of your cylinders (you may not have any, I didn't but better safe than sorry)4. Poor some marvel mystery oil down into each cylinder through the plug holes (not too much not too little use your descretion)5. Replace plugs6. Put in the new oil7. Add some of whats left of the Marvel Mystery Oil into your engine8. Then the rest of the Mystery Oil into your gas.9. Fire it up (it will still smoke but it should run smooth)10. Take it out on the express way and blow out the rest of the access oil thats in your cylinders. (so if you think you added too much mystery oil to your cylinders, as long as you don't flood it, this should burn the access out)11. Once it stops smoking pull into your drive way and give your car a hug.
hope that helps if you have any questions feel free to email me @
[email protected]
This happened to me and this fixed my problem and I haven't had any smoking since.
AdiosJosh
Modified by ViperSRT10 at 7:16 PM 1/6/2006
