smokin..... LITERALY
whosurdaddy018
My ka24de with 178 thousand miles puff out smoke , when u crank it up and when u stop and idle. I know I have a bad 02 sensor and it used to it but now it has gotten worse. Do yall think it is time for a rebuild?
themadscientist
oil smoke? could be worn valve guides
whosurdaddy018
how do i fix it ?
silkk
Car: 94 B13
89 S13
07 S2000
what color is the smoke?
whosurdaddy018
white
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
coolant. You just blew your headgasket.
That or you're running EXTREMELY rich, which means leaking injector(s)
whosurdaddy018
wouldnt a bad 02 sensor make it run rich if so thats the
whosurdaddy018
wouldnt a bad 02 sensor make it run rich if so thats the problem
[Zero-S]
You can try replacing the o2 sensor, but I doubt that is the case.
ricebike
2002 Quest
2005 Altima
plus, run a trouble code scan & see what comes up...
Bigrolla
if u knew ur o2 was bad u should have fixed it, small problems cause large problems so remeber next time
