x240xdrifter wrote:this is actually quite normal, your car has 181,000 miles correct? well your cyclinder walls are worn out from normal engine use/ so many miles, so your piston rings will not seal properly till the engine warms up, and the oil coats the rings properly, the only real remedy for this is to overhual the engine, and I don't know what you would want to do about that but as long as your not getting blue smoke constanty, you'll be fine
That's what I figured. I'm not too worried about it, as the car still runs very well. I'll probably get around to doing a compression check.
First, I just need to remove the clutch fan and install an electric fan.
