smokes when stopped
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
So when i start my car and drive everything is good. usually in the mornings and when i come to a quick stop my car will start to poot out some white smoke for a couple of seconds. It usually goes away and when i start to drive again i goes away instantly. i have had someone tell me its probably my rings but i dont want to hear that. what do you guys think??? i think its my turbo letting some oil past. like i said when im driving and boosting full boost it never smokes
WDRacing
Nah, it's most likely oil leaking into the exhaust from the turbo. Make sure your return line isn't kinked or bent. U may need a restrictor.
VeloceDrift
1995 Nissan KA24DET
cool. that would make since. i think that maybe the return line is the problem because me and the guy who did the work are pretty sure that the return oil is not at the very top of the oil pan so it might be having some trouble draining. thanks for telling me what i want to here.. bad rings=bad new for me
C-Kwik
Check your turbo's shaft play as well.
S13FX
Car: '69 l20b Dimeski :)
VeloceDrift please resize that girnormous signature, unless of course you are trying to make up for something :p
VeloceDrift
1995 Nissan KA24DET
S13FX wrote:VeloceDrift please resize that girnormous signature, unless of course you are trying to make up for something :p
Yeah i do have a small pen15
lrb_2000
Car: '91 Nissan KA-T hatch
really? me too! ... that's why I love my KA-T.
VeloceDrift
1995 Nissan KA24DET
haha.. yeah that KaT helps
C-Kwik
Well, you still need to change your sig:
Quote »1) Maximum sig size is 600x235 (including images AND text): Maximum picture size is 600x200 within a sig along with two lines of default-sized text. Text only should be no larger than 235px high. If you are not sure if your signature meets these limitations, ask.[/quote]
VeloceDrift
1995 Nissan KA24DET
word
