sleeepy240 wrote:hey guys does any 1 know if the air injection device that plugs n2 the exhaust mainifold is nesisary? if so were does the small vacum lines go nd come from?
are you talking about the turbo?? lolon my sr20, there's two coolant lines and one oil line. the only pressure (not vacuum because air is being pushed out) line goes to the waste gate. the waste gate should be coming from either your hotpipe, the pipe that sits between the turbo and the intercooler, or you can tap off of another pressure source. my greddy fmic didn't have a nipple to tap off of and i'm too much of a lazy *** to get one welded. i ended up tapping off of another source.
with my stock intercooler, there was a pipe that sat above my radiator fan shroud. it was a black plastic piece of crap that had a nipple going directly to the w/g. idealy, this hose is as short as possible.
not to threadjack, but here's a link to another forum (sorryyyyy). this helped me a little:
http://www.240forum.com/showthread.php?p=149830
