Right above all these posts.pdudley11 wrote:wheres the sticky that your refer to .....
We are tallking about black smoke (oil) not white smoke (injector leak) correct?pdudley11 wrote:no, the timing chain guides have not been replaced, not since i've owned the car. Would that cause this problem?
How much oil is it using/1000 miles? I think I would just keep it topped off and live with it. When it gets too bad to bear and you see the people driving behind you choking - maybe think about a JDM engine swap if the body and interior are in good shape.pdudley11 wrote:93 Q45 242,000 miles. Car smokes after been idling for about a minute when accelerator is mashed on. Tune up about a month ago, and no oil or any liquid on spark plugs...Nissan mechanic who owns his own shop now said maybe "valve guide rubber" ??? First of all, what the hell is a valve guide rubber (official terminology) and could that be the problem, if not what else could cause the car to be burning oil?
goody94q45 wrote:
We are talking about black smoke (oil) not white smoke (injector leak) correct?
The white smoke, since you didn't mention your engine oil being creamy color (head gasket), could well be from a leaky fuel injector lower o-ring. The blue smoke at start up could be oil blow-by from the cylinder wall being washed with fuel from the leaky oring.pdudley11 wrote:........I've also noticed that when the car is parked and running, just idling, the smoke is blue, but after sitting idling for about a minute or two and i drive off the smoke is white, but the not the kind that results from a cracked head, just white smoke. what would that mean?
You refilled it with a gallon? As in four quarts? That's really low for a 6 quart oil capicity engine! Did you check it with the dipstick to make sure you didn't overfill it? The oil level should be maintained between the upper and lower mark on the dipstick, which is the difference of one quart. You might want to track how many miles it takes to go from six quarts to five (top mark to bottom mark) to help evaluate how much oil you're using. I agree with Scott, if we're really talking about oil consumption in terms of gallons and not quarts between oil change intervals - this engine is seeing it's last days.pdudley11 wrote:When I first noticed that the oil was burning, I didnt refill the tank until about three weeks later when the valves could be heard tapping. I filled it with a gallon jug 5W-30. I think possibly there is a small leak on the valve cover gasket as well, because there is a small drip after the car sits for a couple of days. but if i put a gallon of oil in the car and drive it no more than to work and back everyday, in about three weeks time the valves can be heard tapping! I've also noticed that when the car is parked and running, just idling, the smoke is blue, but after sitting idling for about a minute or two and i drive off the smoke is white, but the not the kind that results from a cracked head, just white smoke. what would that mean?
At least chain guide failure won't cause any loss of life to any innocents.qship96 wrote:Sounds like it could be a fun car to enter in your local demolition derby!
Perhaps the guides have been replaced in the 242k miles? Maybe just not by the CO. From what I've read on the guide issue, having a VH45DE with the old-style guides at such a high level of mileage would be quite a sight to behold, n'est-ce pas?maxnix wrote:At least chain guide failure won't cause any loss of life to any innocents.
And it's only worth what......$1,815? Only fair (generously speaking)condition?
Better it die in faux combat than on the side of the road.
