smoke under my hood
GatorS14
Car: 93/s13/white,96/s14/crashed...ask about parts
there is smoke coming from under my hood between the motor and engine bay(close to the dash) it smells like antifreeze(but i dont know) my rear bumper was really oilly also.It is a s14/AT.
any help is appreciated
yesterday i flushed and refilled my radiator and added transmisson fluid(it could be transmission fluid i spilled some) it wasnt running hot.
And i drove 80mph 45 miles to work this morning(might clear up spilled transmission fluid idea):help
GatorS14
new idea probly radiator over flow! and the rear is probly greasy from driving on the interstate in the rain.(lowered)? comments,help, appreciated.!!!!
Mayhem_J30
Car: Ummm...My Car
i'm moving this for ya.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Oily bumper is not a good sign. Keep a close eye on your fluid levels. If you are having trouble tracing a leak, try and clean the engine bay real good and then drive a little bit, the leak should show up and look fresh. See any puddles? Good luck.
GatorS14
ok,my car is also in the shop getting allighned and they say i have a -1.6 caster on the front right wheel(and recomend new struts)i just got new tein ha's 2 months ago.but they are puttin an esentric camber adjuster kit on it(it is off)and said it might help the caster.
can I get some more help thanks!
Mayhem_J30
Car: Ummm...My Car
i thought tension rods changed caster.
GatorS14
and after an hour of research it seems that way.and i'm probly gonna go with the battle versions' does anyone recomend different?
I'm also looking for opnions on adjustable camber kits(front & rear)the rear is the worst at -1.75
all help is appreciated
Bandit240
Car: 1980 Datsun 720 King Cab
Check your trans fluid cooler lines. Mine rubbed on the motor mount and had a bad leak. I just replaced them with rubber lines.
yellow_jacket
Car: 95 240sx
Like the previous people said, top everything off, clean it all off very well, then see what fluid is gradually losing some or drive it around for a short test drive and then see where your leak is coming from. If you drive at high speed it will make it harder to see though. Be sure to keep a close eye on the trans though, because if you run that low it will over heat and burn up.
GatorS14
well i beleive my transmission seals are leaking,here is why:when i drained my transmission fluid i"splurged" and filled it with B&M TRICK SHIFT. on the package it reads will work with any ATF(automatic transmission fluid).but some thing tells me that it doesnt work with dextron 3 transmissions.:mad:
if anyone can confirm one way or the other i would really appreciate it.:help
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
I dont know about the trick shift stuff, but all I use in my slushbox is mobil 1 sythetic atf.. My transmission loves it and hasnt given me a single problem... Then again Ive been running it since I had around 50k on the odo.
