smoke?
Fla S13
Car: CARS!
ok well i got the car started again and now there is a lot of white smoke comming out of the breather on the valve cover? any sugestion on what that might be??
Dj
boost_boy
Quote »ok well i got the car started again and now there is a lot of white smoke comming out of the breather on the valve cover?[/quote] Not such a good sign at all! Time to do a leak down and compression test. White smoke out of the exhaust valve cover breather is not good news.
Dee
paul_s13
It does sound like worn piston rings causing excess crankcase pressure, a compression/leak test is the way to go.
