smoke once in a while
tony/ka24de
how much oil pressure does the 240 pump? The reason I want to know this is because I think that my oil line for the turbo is to big and too much oil is causing oil to leak through the turbo seals at a higher rpm. Whats the 240sx max oil pressure?
daniel240
Car: cars/motocross
what size is your drain line? it needs to be bigger than your sending line. a bigger sending line wont give you more oil, it will be the same amount as a smaller line, just less pressure.
tony/ka24de
My oil line for the drain is big. But I think putting a smaller feed line would force more into the motor and less up the line. The oil will take the easier path.
daniel240
Car: cars/motocross
you could try it and see, the reccomended feed line is 3AN i think. i wouldnt go much smaller than that. is the turbo old? it may just have bad seals
