driftaholic wrote:my friend var stood behind the car as it ran (i have to stay i the car cuz it won't idle) and said first white smoke came out, then black smoke, then this gunky sooty stuff started flying out in little chunks.
Yikes! My first guess at an idle problem is vacuum leak or EGR sticking problem. I am leaning towards a vac leak because the engine will idle without the maf hooked up. This means its running in fail-safe, and is using preset values depending on throttle position, etc.
Did a repudable shop build this engine? im hoping yes . Did you put the engine together correctly? Timing chain marks and cam alignment are correct? Search the KA section if your unsure, theres plenty of info on that!
Get the engine running (not just cranking must be running) and check the timing with a timing light. Until you get it idling correctly try to time it to 15 BTC (this is 2nd to last mark on the right, looking from front of engine at crank pulley).
Also about the smoke... the stuff coming out the tailpipe actually sounds pretty normal the water from combustion is mixing with carbon in your tailpipe, and well carbon is black... plus theres god knows what in there if its been sitting for a while.
However the smoke from the valve cover is not normal at all. To me it sounds like the rings arent sealed yet since you havent run the motor at all..... and alot of blow by products are having a party in there. Smell of gas could be from incomplete combustion (bad timing again), or your timing could be fine but you may have a head gasket leak and all that is getting pushed in there (which might explain the white smoke but im unsure).
What was wrong with the motor before? If it was overheated you need to have the head shaved to make it flat, Im not sure if iron blocks need to be shaved as well. Just a new headgasket will not do. You can also check your coolant for bubbles or oil. Check the coolant level in the rad (when cold) and check to see if the oil is milky colored.
Make sure everything is at stock values if you have 370's in there set them at the proper correction % and leave it. If you continue to have the no run situation compression test it to find out where the problem is. A quick search will give you the rundown on that proceedure and you can tell if its a potential headgasket, valve, or ring problem.
Sorry if any of this is too basic i dont know anything about the history of your engine, or your mechanical skills. Best of luck tho, dont give up!!!!!
