Smoke from Exhaust + rough idle smells like gasoline
wendys
Car: 1999 Infiniti I30
Hey guys,
1999 Infiniti I30 Base (160,000 miles)
I drove my car to school the other day, went to class etc. When I came back about 3 hours later I started my car and I noticed right away it was idling rough before I even backed out of the parking spot. Idling RPM's were higher than usual at about 850-1000 rpms. I checked the exhaust because I noticed a really strong fuel smell. I see a short jet of smoke from the exhaust and it is dripping some liquid which smells like raw gasoline.
Had the car towed, I was able to drive it out of the parking lot.
I know a lot of people are thinking blown head gasket, but the smoke and liquid leaking from the tail pipe smell like raw un-burnt fuel.
I noticed also that when I turn the car off, there is like 1 second in which the car does not shut off right away like it did before this incident.
I am thinking I have a fuel injector that is stuck open.
Anyone have any opinions or can help me with this issue?
maxhopper
Car: 02 Maxima SE 6spd
Sounds like you are on the right path, with the injector stuck open.
wendys
maxhopper wrote:Sounds like you are on the right path, with the injector stuck open.
Yea, thanks for your input. I just ordered 6 Fuel injectors so I can swap them out.
Do you know if the process is similar to this one here http://www.nicoclub.com/archives/maxima ... ement.html
Going to end up doing it myself. or is there anything else I should do while im in there. Already have a knock sensor ready to swap out as well.
