nab911 wrote:5 speed?A. Some fluid is hitting/in your exhaustB. Your cat is busted and burning up
Auto?
A. You are overheating your transmission
A. If fluid is hitting the exhaust at 60. Smoke would not casually come up through the center console.
B. Same thing goes for the cat. Winds at 60mph would not let smoke rise vertically.
AutoA. I agree with this.
If you have a manual transmission. You might be low on fluid. On the left side of the transmission (facing the back of the car) you will see the transmission fill nut. Loosen the nut gently, if fluid comes out, you are okay and tighten it back up. If it is low you need more. Fill the transmission through the shifter hole, not the fill valve. Once you see fluid start to pur out of the valve, tighten the nut. Also, there are electrical wires running through the console ie: cigarette lighter, E-brake sensor, power mirror (if applicable). Hopefully this provides some assistance.
