Smoke Coming Out of Turbo??
redtop240
Car: 92 240 RB20 Coupe
So I was driving my car at lunch today, came back popped the hood and light bits of smoke where coming out from underneath the heat shield from the trubo? It looked like when you pour water on a campfire that type of puffy smoke. What could that be? If the ceramic in the RB25 turbo was breaking up could that be the cause, or could it possiably be a coolant line running into the trubo, that came loose?
redtop240
Any suggestions?
s14_sport
i've been down this road....and for me it lead to blown turbohopefully not the case for you.
redtop240
what were the signs
s14_sport
lots of oil in intercooler and piping.....loss of oil in the engine (check dipstick)....and smoke out of exhaust when the turbo spools with of course the smoke coming from turbo....
240luvr
Car: '91 240SX KA24DE(T-in the works)
'03 WRX (Daily)
He might check the dipstick if he knew how...
How much smoke is it? Do you have any smoke coming out of the exhaust? A little more info will help diagnose.
If there's a lot of smoke coming from your exhaust there's a good chance you blew your head gasket... considering you're pushing 15lbs on a stock head gasket, with a tune for 8lbs...
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
First question...are you really running 15 psi?
Second question...If so, WTF are you thinking running?
End of thread.
black240jl
Car: black 240sx
if ur running 15lbs ur headgasket isnt gonna jsut blow, also if ur running 15lbs and running it to its max alot, you did most likley blow the turbo due to the fact there not suppose to go to or past 14lbs, thats just my guess
240luvr
'03 WRX (Daily)
I was saying he may have popped his head gasket due to the fact that I understand he runs it pretty hard, and it's not a good tune. It is definitely a better chance that he blew his turbo though, yes.
Was the car running when you popped the hood and saw the smoke? Or did you already shut the car off? Just wondering, again could yield different opinions...
Rb20_POWER
Car: '90 240sx w/ rb20det
check coolant lines on the turbo to make sure nothing happened to them..
