Abaker13 »
https://forums.nicoclub.com/abaker13-u174768.html
Wed Jun 20, 2012 8:05 am
Ok heres a little bit of the car. Its a 96' S14 w/ RB20DET engine, RB25 Turbo, and RB26 cams and injectors. Also recently installed was a NIStune but hasnt been tuned yet. To the problem, when I start the car and then once its on I have smoke that comes from the steering column, I opened up the steering column and its coming from a brown wire the brown wire is connected to the connection that plugs together under the column. Ive been searching through wiring diagrams and the only thing I can think of is the o2 sensor. Ideas? and if it is the o2 sensor if I unplug it since I just picked up a wideband will I need to worry about this wire anymore since theres nothing going to it anymore if it is the wideband?
Tried uploading pics but for w/e reason its not showing them, but any ideas would be greatly appreciated!
