smoke coming from exhaust manifold, help?!
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
i just did the third treatment of seafoam through the breakbooster hose and when i did this white smoke started coming from the exhaust manifold, specifically from the 4th spark plug area, it wasn't coming directly out of the spark wire or plug itself but it was coming from around that area, don't know what it could be but i know i have exhaust leaks, do you think it could be my manifold has a leak?
gumby
Car: '89 240sx sohc
good excuse for headers :D
DrifterXRPS13
yea but i only have a certain amount of money and i can't decide what will help me pass emissions, does anyone know what it could be?
ricebike
2002 Quest
2005 Altima
i think gumby confirmed your guess that it is an exhaust manifold leak...
he's being coy since you'll haveta remove & reinstall the manifold to replace the leaking gasket... might as well put in a header? no?
side note: i too have a minor leak w/ 1 visible exh head bolt stripped off... not gonna play w/ it until my engine needs to be pulled...
gumby
Car: '89 240sx sohc
i think you can get OBX headers shipped for around $200
DrifterXRPS13
how are the headers for emission purposes?
ricebike
2002 Quest
2005 Altima
they're not... u r better off using the regular exhaust manifold...
the Catalytic Converter is more for emission purposes; saw u on buy/sell/trade forums... any luck getting a whole system yet?
Hopefully, the used cat is not totally crapped out on u when u receive one from another member. I was lucky that a guy sent me his whole cat back system, w/ a fairly new cat along w/ it since he was goin turbo & using a "test pipe" instead...
DrifterXRPS13
yea i've been trying to find an exhaust, but peeps just don't want to ship out...what if i get a high flow cat, would that be better/worse than getting someone elses used cat for emission purposes?
ricebike
2002 Quest
2005 Altima
Captain Obvious will say better (new>used)
agh, wasn't there a local guy u can pick it up from?
