Hello Centralcoaster, thank you for your answer.
Yes, the old one seemed to be clogged with oil. I already looked a little bit into the hoses, I found that there's oil in here
https://drive.google.com/open?id=149bI7 ... 0FH7oE25a-
https://drive.google.com/open?id=1DTYGs ... bulhvN2JTw
I found oil and some smoke in there.
It's the box that goes connected to the air hose intake after the filter, but i don't know what's this box for, is it for chance an oil/air separator? if it is, then that might be the problem, I will try dissasembling it tomorrow from the other side to see if i see oil in there. I have been looking in the manuals but there's no description for this item
Looked in the EC and EM manuals.
Yeah, i'm not thinking in changing the o2 sensor, i don't think it's failing, i will first look for this problem
I will be checking this box that i don't know what it does, and if i dont get to anywhere with it, i will try a compression test I guess
Yes, it is automatic, in fact, CVT
Thank you again for you answer
and greetings from Mexico!
