Smoke and idle problems
vis213
Alright I bought this car sunday and everything seemed to be in order except a smoking problem when accelerating. Well now she only wants to idle at around 400 and at that much its shuddering like a monster and the power feels nothing like it should be, I could floor it and she would act like your about 1/2 - 3/4 on the throttle. I was recommended to change my fuel filter, check the coils, and check the timing. Now if my timing is a bit off all I have to do is turn the CAS into the right position right?
biosehnsucht
also check the spark plugs (i.e. make sure they're not fubar) and look for intake piping leaks (boost/vacuum leaks)
also if you have a multimeter or ohmmeter check the resistance of your coilpacks, see the FSM on how to do it.. if you don't have it, download it, I think one of thestickies at the top has a link.
wildacexxx
Car: 2002 Q45 nav sport
check your compression u never know if its the rings
