redincali »
https://forums.nicoclub.com/redincali-u102928.html
Fri Sep 24, 2010 1:04 pm
Ok well let me just start from the beginning... The car was running ok, but there seemed to be a lil lag when i gassed it on the freeway.
1.Theres oil on the underside of my hood in a perfect line. From where it seems to line up, it seems that its coming from the timing belt area. I have 4 seals from a gasket kit so im hoping its a bad seal.
2.Next, theres a sound coming from inside my driver side fender. it reminds me of a card in a bikes spoke. if i hit the gas, the sounds revs up with the engine. im at work at the moment so next time im home ill make a sound clip
3.There was a strong gas smell coming from the engine bay, especially if im parked or i turned the air blower on in the car. i smelt around the engine and it seems to have been comig from the injector area. i did change 3 injectors a few months ago and noticed the seals we looking bad, but since i hadn't smelt gas at that, i didn't change them.
4.Recently ive noticed a small spot, like 4-6 drops, of oil where ever i park, i thought maybe it was just run off from oil from the timing cover. so i looked under the car and theres alot more under there than i expected. ill have to do more looking but it looked as if it were coming from above.
5.When starting my car in the morning, i have to give it gas til it warms a lil bit. then ill be going, see the light ahead of me turning red so i prepare to stop, i downshift and put it into neutral when im around 10mph and at this time my enginges at a steady 1-1.1k rpms. i hit the brake and as soon as im at a complete stop, the engine tries dying so i have to tap on the gas until my light turns green.
Well it was time to smog so i figured, f-it ill just see what they say. wow, it was way off. no papers with me at the moment to give numbers but im thinking the emissions was about 3k over and the knocks(?) were around 1k over. fuel cap was bad, so i replaced it, visual failed because the last owner of the car used wire nuts to connect wires, and i wouldn't doubt if a wire was disconnected somewhere or missing completely.
so this is what i did on my 2 days off. pulled the plenum, removed the egr (without moving the engine or transmission), put the new egr in, removed the fuel rail and changed the fuel rail to lower plenum seals, blew out the egr pipes with air, soldered and shrink tubed about 10 wires, put on a new plenum gasket and reinstalled plenum. got everything all hooked up and noticed the fat vac line coming off the back of the balance tube is hissing, its on at an odd angle and isn't long enough so that will be replaced.
what i did notice with the plenum off is that the metal line on the underside that connects to the egr, and egr solenoid, was curved back to go under the plenum so it wasn't even attached. i thought the solenoid was actually gone until i noticed it was on the bracket my friend had removed. also, there was a small amount of oil inside of the plenum and was in the pcv valve hoses coming off the underside of the plenum.
now everything is back on, i prime the fuel pump a few times, start the car and it starts up great and tries to die like normal but now the gas pedal feels stronger and more responsive than before (didn't notice a fuel smell and i was hoving over the engine, its how i noticed the balance tube leak) and the car actually sounded a little more aggressive than before as well. it was 11pm so i coudln't do any more work for the day. I want to check the egr solenoid still, i have 2 new o2 sensors to put in, and two new cats as well ($170 each, ouch).
I may have forgotten something so if i did, ill add it instead of editing this post or else it might get lost in the mix. but if anyone has any help, it would be very much appreciated. i look all i can for answers before asking for help in my own post so any information will help, thanks in advance everyone.
