Smog Canister Question?
WDRacing
Who has removed it? I ripped mine out last night...much more room there now. Any problems related? Where do those lines off the bottom run?
Drift Machine
Car: 1991 KA-T 240sx
Yeah I want to know as well, since I was ponderin rippin mine out this summer.
Structure240sx
that can behind the drivers headlight?
ripped mine out no difference after, i just capped everything going to it. under neath lines i thought was the vent for the fuel tank. im not sure since its been a while
WDRacing
Structure240sx wrote:that can behind the drivers headlight?
That makes sense...Well mine aint goin in anymore. I smashed my knuckels on a stud and beat the canister with a ball peen hammer until I felt better
Structure240sx
what are u in the Mob?
WDRacing
Structure240sx wrote:what are u in the Mob?
I'm all Irish...so I have a really bad temper and I drink alot...lol. So IRA would be more along my lines.
Nismo_Freak
Car: 89 Nissan 240SX
It's just the gas evap. emissions container. Make sure you cap all the lines or you will have issues.
virus77
Car: 95 S14, 71 240z, 97 e320
No adverse effects, just use some good'ol screws to cap the lines, theres like 4 or something.
nissanfanatic
Car: 1992 Nissan 240sx SE
No problems here. Agree with capping lines. Mine is laying in my room somewhere with the rest of my "Unnecessary parts,".
toki
line the bottom is the gas tank vent, the rest are random BS vac lines.
crzycav86
Car: 93 Nissan 240SX KAT
So are you guys just capping the fuel line? You know it's there to relieve pressure in the fuel tank...
What adverse effects would you have if you just let that fuel line vent into the atmosphere.... and what problems might you have if you capped it?
onosqv
Car: '92 240sx Vert
This smog canister right (below)?
If we can remove this w/ no adverse affects that would help me a ton (like someone else said, it's to relieve fuel pressure and evaporate the gases - I'm guessing so it doesn't build up too much and becomes dangerous in an accident or something?)
Mine is kind of just dangling around, I'm afraid it will hit the pulley belts later on.
**EDIT: well, apparently, I can't link to an image I attached for vacuum line questions from another post. Also, somehow I've lost the ability to attach an image for this thread even when I click reply... o well:
klattr1
Car: GT42R powered S14/KA
crzycav86 wrote:So are you guys just capping the fuel line? You know it's there to relieve pressure in the fuel tank...
i just vented the lines that lead to the hard lines coming from the fuel tank.
all the other vacuum lines just need to be capped (coming from underneath TB area)
WDRacing
klattr1 wrote:i just vented the lines that lead to the hard lines coming from the fuel tank.
Ditto
klattr1
whats your vacuum like at idle (800 rpms) WD?
onosqv
Car: '92 240sx Vert
Anyway you can show me a pic of what should be capped & what should be vented? I'm a little slow/confused.
Just a regular rubber cap? do I need to get a tiny clamp for it?
Where are the lines that lead to the hardlines coming from the fuel tank?
Thanks so much, yea mine isn't going back either, haha, so it's best if I remove it completely.
