C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Mar 07, 2008 2:10 pm
Bedding in should take into consideration the pad manufacturer's recommendation. It varies from one manufacturer to the other. However, some manufacturers take a legally conservative approach to bedding by not recommending people go accelerating and braking up and down the street. Generally, a more aggressive bed-in is better than driving around on the street normally.
I'd agree that Powerslot's recommendations are extreme. But I would not be going by their procedure as the pads are being bedded in, not the rotors manufacturer. Interestingly, while you claim Powerslot's bed in procedure to be overzealous, Tire Rack indicates power slot recommends a very conservative bed-in.
I'm not trying to suggest everyone go and overheat their brakes. I am merely pointing out that the intent is to get it up to a certain temperature. Keeping it too cool will not sufficiently eliminate green fade nor leave a sufficient layer of pad material on the rotors. The rate of temperature increase should be controlled, but not necessarily the overall temperature. Again, depends on the pad.
Not coming to a complete stop is done to prevent a thickness variation caused by leaving an imprint of pad material on the rotor where it becomes an area of higher friction than the rest of the rotor . With use, such an imprint can lead to uneven wear which usually gets misdiagnosed as rotor warp. Extended periods of driving like this or in extreme cases, you get cementite, where carbon from the pad actually imbeds into the rotor and can turn into cementite. At this point, your rotor is likely ruined. Even turning a rotor may not help as cementite wears slower than iron, which will become a high spot as the softer parts of the rotor wear down.
