crxcess »
https://forums.nicoclub.com/crxcess-u12058.html
Thu Mar 04, 2004 5:09 pm
Check the gas tank seal first. The charcol canister only stores vapors when the car is turned off, once the car is turned on and off idle it vents into the intake. Its a valuable device, and venting the fuel tank vapors to air may make more fuel smell then before. shake it... it should sound like its got sand in it, if not it may be saturated with fuel, and in that case I would just replace it rather then cap it off.
