govols0511 wrote:Hello...
I'm wondering if anyone has been having the issue of smelling antifreeze in their Murano? It's not real strong and isn't constant, but it is there. There have been some posts about it, but no real conclusions. I don't want to wind up with engine failure down the road. Thanks for any info.
Doug2009 LE AWD
Hi Doug,
I was one of the initial posters of this topic. My wifes 09 LE, purchased in 08, has had the smell since the first week. I have never found nor seen a leak yet the coolant level does drop very slowly over time.
Is your smell more prevalent on the drivers side? This seems to be the case with those that have the leak. A few stated it was the rear head-gasket seeping down onto the transmission.
I too notified my dealership early on yet they could not find anything via sight and a pressure check resulted in no leak down... They said they couldn't smell it of course. JUST make sure you get your complaint documented on a work order! I was a Nissan Tech for many years and I know an antifreeze leak when I smell it. This one is obviously out of sight and the liquid is evaporating prior to ever coming visible or hitting the ground.
Troubling, yet my wife is approaching 20K miles on her 09 and the smell and/or illusive leak doesn't seem to have changed or effected performance. I do believe this will be a larger issue down the road both for customers and Nissan.....
Keep us posted on yours
